Help me spec a HTPC
18 Dec 2008
Liverpool
Okay Guys I'm thinking about building a HTPC using some of the guts from my current system...
I'll most likely be keeping the following for it...
  • Intel Core i7 920 D0
  • Foxconn Renaissance
  • Coolermaster Real Power 620w Modular
  • OCZ Gold 6GB (3x2GB) DDR3 Tri Channel
  • Western Digital Caviar Black 640GB
Could you please spec me the rest of what I would need for the best overall HTPC system... It's to be connected upto a 50" HDTV
Thanks...
First of all make sure you get a decent case, Lian Li has a lovely HTPC case, its not cheap but since it’s for the living room paying the extra for atheistic’s is justified IMO. You can also fit a full size video card in there as well as TV Tuners and sound cards.
The choice of TV Tuner is up to you but get one that has a double tuner so you watch and record TV at the same time. You might as well get a BLU-Ray drive since there now affordable but consider a video card like a Radeon 5770 so you can play sound out using true HD Bit streaming, also a card like that will serve as good gaming card as well.
Lastly and this is the most important part is the choice of software, I can’t choose for you but there’s 3 basic choices – Windows 7 Media Centre, XBOX Media Centre (XBMC) or my personal choice Mediaportal. There’s also a range of Linux solutions as well but I don’t much about these.
