Help me Spec a mATX system for iRacing
5 Jul 2010
Hi Folks,
I'm looking to build a mATX system for iRacing (http://www.iracing.com).
I have spent many many years in the Mac world, where decisions on specs are all made for you by Apple, so a hand in the right direction would be great.
I am building into a mATX case as that's all I have space for, plus I already have the case, which is a FreeNAS Atom based system at the moment.
I am on a reasonably tight budget, but would like to make sure I am spending in the right places and that I have some upgrade possibility/paths in the future too.
So, how do you guys think this setup would work for iRacing? Would I be able to run reasonably decent frame rates etc?
Gigabyte GA-880GMA-UD2H AMD 880G (Socket AM3) DDR3 microATX Motherboard - £74.99
HIS ATI Radeon HD 6850 1024MB GDDR5 PCI-Express Graphics Card - £149.99
AMD Phenom II X2 Dual Core 555 3.20GHz Black Edition (Socket AM3) - £89.99
Patriot Viper 4GB (2x2GB) DDR3 PC3-12800C7 1600MHz Dual Channel Kit - £61.09
Total: £376.06
The mobo choice is based on a mATX that I can run two graphics cards on later for an upgrade / tri-monitor setup.
Thinking of pairing this with a Hanns.G 28" monitor.
An idea on the power supply requirements for this spec? I already have a 300W supply in the case.
What do you think to the choice? Anywhere I could better spend my money? Or any better options?
Cheers,
Jim
That mobo can't run crossfire, you would need this mATX motherboard to do that.
As for the power supply, I would get a new one. A full 6850 system at max load will draw about 250W, and I'm guessing it was a cheapo one that came with your Mac. In other words whether it will actually run at 300W is debatable and you don't want a generic PSU blowing up your new components.
What is your full budget?
Hi,
Ah! I read this in the description "dual PCI Express 2.0 graphics interfaces (running at x8 and x8) for ATI CrossFireX/ATI Hybrid CrossFireX support" and presumed I could do crossfire. Am I missing something there?
Also, how important is DirectX 11? And would either (or any) of these mATX mobos support it?
I don't really want to go over £400 for the lot excluding the monitor which I will buy separately.
Here is what I already have:
- Super Micro Mini-Tower SC731 (which has the 300W supply)
- Windows 7
- 1TB 5200rpm HDD (I have loads of these! Will I be ok using as a boot drive?)
- Keyboard/Mouse
Many Thanks,
Jim
Sapphire ATI Radeon HD 5770 1024MB GDDR5 PCI-Express Graphics Card £117.49
MSI 890GXM-G65 AMD 890GX (Socket AM3) DDR3 microATX Motherboard £99.99
AMD Athlon II X4 Quad Core 630 2.80GHz (Socket AM3) - Retail £69.31
Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit £61.09
Corsair CX 430W ATX Power Supply Corsair CX 430W ATX Power Supply £37.98
Total : £397.61
dont trust power supplys that come with cases, theyre often cheap and inadequate for modern gaming systems with hungry graphics cards, my spec is mildly older then yours but includes a decent PSU for a small price increase.
Hi again folks,
Really appreciate all your help. Another question though:
The MSI 890GXM-G65 only supports DirectX 10.1, how important is that?
Are there any AMD mATX boards that support DirectX 11?
Jim
Hi again folks,
Jim
The onboard graphics card is DX 10.1. You are using a standalone, so it's irrelevant.
