Ok so took one of the cards out, just ran Unigine Heaven tool on extreme for 10 mins and the fans maxed out at 44% and the card hit a maximum of 69 degrees at 100% load!!
I'm going to test the 8x pice lane now then the other card on both lanes. Will report back with findings.
But surely running them in xfire couldn't make both cards run 30 degrees hotter could it?
Card 1/PCIe 16x
Fan Max 44%
CPU Temp Max 69 Degrees
Card 1/PCIe 8x
Fan Max 50%
CPU Temp Max 73 Degrees
Card 2/PCIe 16x
Fan Max 47%
CPU Temp Max 71 Degrees
Card 2/PCIe 8x
Fan Max 46%
CPU Temp Max 74 Degrees
All of these maximums were taken when the GPU Load was at 100%.
So, crossfire just runs crazy hot or can we draw any other conclusions? Any thoughts?
Card 1/PCIe 16x
Fan Max 44%
Card 1/PCIe 8x
Fan Max 50%
Card 2/PCIe 16x
Fan Max 47%
Card 2/PCIe 8x
Fan Max 46%
