- 31 Jan 2011
- Hampshire
Hi Guys
So the time has come to upgrade my server, Currently a Single Socket board with E3-1226 v3 @ 3.30GHz 16GB ECC ram and a 1060 gpu (used for HW encode/decode) HW Decode is still very flakey with plex on unraid with patches needed so its not yet perfect enough in my eyes.
The server is used for a VM (light to medium multi use)
Plex (by far its biggest task can have 3/4 users all needing transcoding at once)
CCTV (not too intensive)
A virtual Synology machine to handle some tasks
File server etc.
However i would like to go a little overkill with ideally some cheaper used hardware. Im thinking of finding a dual socket LGA2011 board and sticking two E5-2690's in in or something along those line. Threadripper and DDR4 is just too expensive at the moment for what i use it for.
I have a 800watt PSU so thats all fine and its in a very large rack mount case with 11 HDD's connected and 2 SSD's for cache and OS of VM's plex library database and images etc.
is there any disadvantage to going dual CPU apart from extra power consumption? What would you do with say a £500 budget? if i can get in below £500 on used hardware im all game. what i really want is lots of thread count. is there a CPU that sticks out for this application? im a bit lost when it comes to server stuff tbh and i know i can move away from server grade stuff but always had the thought it should last. the E3-1226 i have has been on from new for many years now and never once have i had to restart it.
Currently connected by a single LAN cable but i have a 4 port NIC that i would like to pop in. oh and my existing board only has 3 PCI slots that i have completely used up with 1X 1060 and 2X 4 port sata cards so a board with lots of SATA ports would also be great.
File server etc.
