- 16 Jul 2010
- London
Hi Overclockers, after some guidance please planning to upgrade my cad/camm pc workstation within next month or two the nature of my work its on 24/7 processing data, running simulations and any reasonable ways to reduce my electric bill a real consideration in my upgrade. My workstation is knocking on a decade old now although its served me well definitely time for upgrade to latest technology. To be frank I am totally bewildered with vast variety of options available these days shops visited just spurt strings of numbers and letters pushing me into what seems a biased sale.
Not sure model of my case its Antec branded yes its old yet still looks discreet and modern i like to retain, it has space for 2x80mm fans on front and 2x80mm rear of case (all currently unused) and PSU located up top. My current motherboard is old dual socket cpu in E-ATX format, from the motherboard to inside edge of case is approx 110mm deep if that makes a difference since today’s coolers look massive compared to my current coolers which are matchbox size!
I never play games so I’m happy to sacrifice 3D gaming prowess however running lots of office and internet apps heavy multi-tasking being able to play latest HD content and blueray is as much graphics power my work demands. With it being kept on all the time processing data in the background could this be called idle? Im on Windows XP Pro most of my software I doubt is multi threaded being old as it is however planning to upgrade all my software to latest version in next 6 months which definitely takes advantage of multiple core/threads (dont know the difference) would I be better off upgrading to Windows7 now? My main issue is motherboard which can at minimum support latest high end 6 core cpu that’s well laid out with reasonable access and upgrade path with latest i/o standards is priority. Hard disk wise my work is very data intensive must have reliable fast hard drives 500Gb be ample for now really need some suggestions here, is going raid worth while? is it like double the performance or more like 20% faster? Ram 4gb with room to upgrade, ram specs I have no idea same with PSU preferably one that doesn’t sound like a helicopter within a year be great.
And ofcourse budget around £500
Normal F3 should be pretty energy efficient anyway.
