- 22 Aug 2010
- In My Command Center
i have googled this and come up with nothing does anyone know how to remove these cables i have the tools but cant seem to do it?
thanks
Use a penknife blade to depress the latching barb fully down into the terminal body. If you don't push it down far enough it'll remove material from the connector as you yank it out and compromise latching back in once you re-assemble. You shouldn't need to pull the wire that hard to get them out if you press the barb properly.
What's the cable for anyway? Curious.
Pulse Modding Fan Pin Removal Tool about £4 well worth buying.
