help me perform a bios flash
i have an a-bit AW9D-MAX motherboard and i need to do a BIOS flash/update so i can start using my Q6600(B3 stepping) however i can't make sense of the instructions on the a-bit site
to flash the bios they say to make a bootable floppy am i right in assumming that means to format the floppy in MS-DOS mode however this leaves the floppy without enough room for the bios file when extracted (which i assume i should have done before copying the files to the disk). my guess is that the floppy does not need to be in MS-DOS mode however i am unsure if it would destroy my motherboard or not.
please help by giving me very clear instructions or an alternative method of flashing my bios.
p.s i don't have an alternative motherboard to use if this board dies so great care and advise is wanted
