Help me upgrade a little!
OcUK Staff
12 Apr 2008
OcUK HQ
I would like some recommendations for this system, this is what I have:
Asus T3-P5G31 Barebones System - Intel Core 2 Duo (LGA775) (I have the same as this one, but does not support Quad Core)
Corsair XMS2 4GB (2x2GB) DDR2 PC2-6400C5 TwinX Dual Channel (TWIN2X4096-6400C5)
Seagate Barracuda 7200.10 250GB Sata-ll 16MB Cache (Not sold on OcUK any more)
Pioneer DVR-216DBK 20x DVD±RW SATA Dual Layer ReWriter (Black) - OEM
Intel Core 2 Duo E7400 LGA775 'Wolfdale' 2.80GHz (1066FSB) - Retail
SteelSeries QcK Mini Gaming Surface
Things I am looking to upgrade are:
My mouse, I was thinking of getting this:
Microsoft Intellimouse Explorer 3.0 Optical Mouse - Retail (B75-00115)
Keyboard... Not sure, I don't want a gaming one as such, but a nice one which is nice looking and worth the money, wired would be nice.
I would like new speakers, I am a big fan of Logitech and I was thinking of replacing my 2.1 speakers to a 2.0 to give myself more room.
Also what parts could I add or change in my system which would give a nice improvement?
Any advice is appreciated.
I was thinking of getting this graphic card for my system it should be fine as OcUK use it in their systems for the same barebones as what I have.
Sapphire ATI Radeon HD 4350 512MB "Low Profile" DDR2 TV-Out/DVI/HDMI (PCI-Express) - Retail
Also thinking of upgrading my monitor, which one would you go for out of this list, and why?
http://www.overclockers.co.uk/productlist.php?&groupid=17&catid=948&sortby=priceAsc
Basically the list of things I would like to upgrade is:
Optical Drive
Speakers
Graphic Card
Monitor
Mouse
Keyboard
Monitor wise, that'd be your best bet, good res, its between that n the dell, the other one (sammy) with the higher res just has built in freeview which I take it youre not bothered about, so either this sammy or the dell, either would do, I like the glossy finish on the sammys though
re the rest, what are you actually wanting the system for?
The system is just for media, office, internet and personal use really. Not a gaming machine obviously :)
But I would like to use it for mainly for office use,
If its for office work, I would stick with what you have and just go for the recommended monitor, it will run well :)
Have you condidered an mx1100 I've got one of these and it is an understatement to sayt a comfortable mouse can make using a computer less of an arduous task, find a mouse that suits you, personally I like a large highly sensitive mouse that is heavy
