Hi there
My current spec is:
MSI Z97S Motherboard
Intel G3528 CPU overclocked to 4.5hz with after market cooler
8gb 1600mhz Ballistix sport ram
Monitor is a ProLite E2208HDD
MSI Nvidia GTX 970
I'm looking to spend around £500 - maybe £600 absolute max.
I was originally set on getting an Intel I5 4690k with another GTX970 to SLI - but is there a better way to get increased performance?
Should I consider changing the ram to 16gb 1866mhz?
Should I invest in a better monitor? 144 refresh rate, G-sync or 1440P? I do have my eye on a AOC G2460PG - but would the increased performance of two GTX970's beat the enhancement a monitor upgrade might bring?
Any advice is very welcome as I know very little other than what went into my first build!
Thanks.
My current spec is:
MSI Nvidia GTX 970
Thanks.
