Hello all
I am currenty studying for MCSE and need to run a few VM's.
In order to run 4-6 virtual machines I was thinking of whacking in a couple of gigs of RAM as my 64 bit Vista really struggles to run more than a couple of Virtual OS's at once.
Mobo won't take more that 4GB RAM.
I don't really have the money to do a complete overhaul of hardware, but can't help but wonder if I might be better off upgrading CPU, Mobo and RAM all at once to get a real performance increase.
Can anyone recommend cheap RAM or basic mobo, RAM, CPU spec to run all this.
Max budget £200 ish for PC
£40 ish for just RAM
I have the following
AMD Opteron 165 Socket 939 1.8GHz Dual Core 2x1MB (running at stock but can run at 2712Mhz oc'd)
2 x 1GB Corsair XMS 3200 CL2
4 x Seagate ST3250823AS 250GB 7200RPM SATA/150 8MB Cache, RAID 5
SATA2 160GB HDD 10000RPM (Cant remember make)
Enermax Liberty 620W Modular ATX2.2 PSU
Asus A8N-SLI Deluxe S939 NF4 SLI ATX
Big Typhoon CPU air cooler
1 x CD/RW
1 x DVD/RW
1 x CD/RW
1 x DVD/RW
