Help me use my X360 tonight!
24 Feb 2004
St.Andrews
I have just got back from a LAN and reconnected my 360 to my Sammy LCD TV to begreeted with the 'Not Supported Mode' display :(
The screen it was plugged into at the LAN was running 1280*1024 and the TV won't support that. I need to set the X360 back to 1280*720.
Can one of you lovely people tell me the eact button press sequence to get from the initial boot up screen to the resolution changing screen please?
Plugging the X360 back into the monitor isn't an option as I've wired up the X360 now andI ain't lugging it all back upstairs :|
give it 30 secs to login, etc.
go right three times, press a, press a, press a.
press up twice for 1280x720, press a (screen should come to life), press up, press a.
Not just a pretty face, eh?
What can I say?
Your obessesion with it has rubbed off on me :D
Killed the dragon dude and Alma at the LAN and got as far as getting run over by a tank as well in the Military Base. All with no sound - so I shall replay them for a bit of fun :D
Davey_Pitch said:
Hey fella, added you to msn earlier in the week for our Fight Night match and for something I wanted to talk to you about re these forums although Im not sure if you accepted it?
NG works on the 360 eh?
Was gonna get it for oldel xbox.. but if its all good on 360 a top cheap game would be star!
GRAW and NG? sounds good to me.. all for my ps2.. worth it though!
Aye mate, accepted you earlier today, though not online right now. I'll sign in tomorrow so I'm sure you can catch me then :)
Err..you might have accepted me too?.. because coincidentally my name is Rob too.. if Roboffers is?..
anyhoo, is Ninja G emulated on 360?.. any updates/improvements?
It's the same, only issue is a little bit of frame loss.
Yep it's only occasional however and very consistent with where it happens . Also it makes fighting incredibly easy :> Not to mention Izuna Drops look cool as hell in slow mo :D
//edit:
Just re-read this thread - holy huge tangent batman :>
