- 14 Jan 2014
First of all hello, started using OCUK many years ago for parts, been a browser here for ages but never posted, thought you guys might be able to help me with a new build, my nephew was going to have a PC bought for him, so I suggested they buy mines and that way I get to make a new build!
I'll be looking to order this in the next month or two.
My current specs are, i5 3450/7850 Twin FROZR/2x4GB RAM/Sandisk Extreme 240GB SSD/Corsair CX430 V3/Bitfenix Prodigy/Dell U2312 IPS monitor.
I'll be keeping the monitor&SSD (SSD is going to my Macbook Pro). Requirements for new build are, custom water cooling loop (first time doing this), has to be quiet, black and green theme, NVIDIA GPU (been with ATI for ages, fancy a change and really want to try Shadowplay). Computer will be used for gaming. Not got a set budget, but I'm not rich. I've already got a rough idea but it's not finalised, here's what I'm thinking.
CPU - i5 4670K
Motherboard - Gigabyte Sniper M5 mATX
GPU - GTX770 (not sure which brand is good? EVGA? Needs to have a compatible water block)
RAM - 2x4GB or 2x8GB, 1866mhz, maybe Avexir? That's if the LED's aren't always flashing away and being distracting (probably the former, unless games are actually going to start using past 8GB)
Storage - 500GB Samsung Evo. I can't go back to HDD storage for OS and even my steam collection now, too used to using an SSD as my only storage for these things. Also need a 500GB 2.5 inch HDD for Shadowplay footage (going 2.5inch due to the Arc Mini having space behind the motherboard tray to fit 2 SSD's, so was planning on putting this in the second SSD slot).
Case - Fractal Design Arc Mini R2 Can fit a 360mm+240mm radiator in this mATX case to my knowledge.
PSU - XFX 750w Black Edition
Radiator Fans - Corsair SP120's Quiet Series
Case Fans - No idea, any recommendation's for something quiet that pushes a decent bit of air and matches the theme? Not sure how the Bitfenix Spectre's hold up.
Radiator - XSPC RX360 V3+XSPC RX240 V3 (Awaiting reviews)
Pump - Some sort of D5 variant.
CPU Block - Unsure, must be black, no copper look.
GPU Block - Unsure, must be black, no copper look.
Fittings/Tubing - Compression fittings (not sure which), no idea whether to go green tubing and distilled, or go clear tubes and some green Mayhem's (the stuff that isn't for show cases and lasts a while?), also unsure of size for tubing.
Reservoir - Tube one, no idea which.
Apologies for the lengthy post, as you can probably tell I'm pretty OCD with researching and planning, don't want anything to be missed. Any help and input would be much appreciated, look forward to your feedback!
CPU - i5 4670K
