Help me with my case air flow
23 Oct 2012
I'm a bit worried about the airflow in my case, the reason being is when im gaming my PC case feels really hot to touch, however Afterburner says my CPU is around 52c (never goes above, 57c and its watercooled) and my GPU goes to around 70c however when i put my hand over the vent it feels really warm.
Here's a paint diagram of my case, the red squares being fan mounting points, im wondering which should be intake and which should be out take fans. Thanks for your help.
The one at the back is my H55 pre liquid CPU cooler fan, i have this as an exhaust fan, is this correct?
I have that case on my work PC. Its very good actually, very roomy with lots of airflow. I would leave it as it is. Yes having the intake at the bottom means you have dead air at the front of the case ....but then again....so? nothing needing lots of cooling there. The way you have it the fresh air goes straight to the GPU and mobo. Its a good setup. Very dusty though.
