- 14 Jan 2014
Hello guys, I've always wanted to make a W/C build, but every time I make a new PC, I bottle it last minute and go air. This time I've decided to man up!
Specs wise it's looking something like this..
6700K
EVGA 1080 FTW (Has arrived)
2x8GB Corsair Platinum 3200Mhz
Asus Formula VIII
EVGA Supernova G2 650w
Dell S2716DG 1440p/144hz/g-Sync (Has arrived)
Here is what I'm thinking for case and watercooling parts.
My basket at Overclockers UK:
Total: £536.16
(includes shipping: £15.30)
I'm going for a black and purple build, I'm not sure on liquid/fittings/fans. I want my coolant to be purple, but still transparent (not the thick stuff). Was thinking of Mayhems X1 or XT1? Tubing wise I was thinking either Mayhem or Primochill 10/13 tubing?
As for fans I looked at EK Vardar's, as well as NB-eLoop's, sadly the latter is only available in white though, which may rule them out. I've gone for thin radiator's and I would like good lower RPM fans for them.
Fittings wise I will probably go for Bitspower matt black, I wonder if I can get purple o rings, they all seem to be green.
Sorry for the long thread, look forward to your input
6700K
Asus Formula VIII
- 1 x Phanteks Enthoo Evolv ATX Glass Mid Tower Case - Black= £164.99
- 1 x EK Water Blocks EK-FC1080 GTX - Acetal+Nickel= £94.99 (Will be changed to relevant FTW block once released).
- 1 x EK Water Blocks EK-Supremacy EVO - Nickel= £54.95
- 1 x EK Water Blocks EK-XRES 140 Revo D5 PWM (incl. pump)= £106.99
- 1 x EK Water Blocks EK-CoolStream SE 360 (Slim Triple) Radiator= £54.95
- 1 x EK Water Blocks EK-CoolStream SE 240 (Slim Dual) Radiator= £43.99
Total: £536.16
 So I'll be good if I buy a Bitspower t-fitting&valve?
