- 13 Sep 2011
- N.Ireland
Ryzen 5 3600 wraith cooler I am told won't be sufficient for keep temps down enough. Which cooler is good for ram clearance?
this is what im using. Ryzen 5 3600Ryzen 5 3600 wraith cooler I am told won't be sufficient for keep temps down enough. Which cooler is good for ram clearance?
If you do a lot of heavy core work loads then it might struggle but if you just game it will likely be fine. That said I got a free wraith prism cooler since my brother didn't need it for his 3700x and it's been very good keeping temps around 55c for gaming and 67c when running aida/cinebench so if you can pick one of these up for around £20 quid I think it's a bargain.Ryzen 5 3600 wraith cooler I am told won't be sufficient for keep temps down enough. Which cooler is good for ram clearance?
Will look into this one. Thanks.this is what im using. Ryzen 5 3600
Be Quiet! Dark Rock Pro 4 CPU Air Tower Cooler, tewmps are good in games highest 55° idel 35/39°.
hope this helps.
