1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Help me with some sliding divs in jQuery
Discussion in 'HTML, Graphics & Programming' started by A.N.Other, 16 Jul 2011.
  1. A.N.Other
    Sgarrista
    I've got a problem I've previously solved with mootools, but I'm looking to translate it into jQuery to integrate nicely into Drupal. Can anyone take a look over it for me?
    The idea: a cross between an accordion and simple sliding divs. I have a set of links in the footer (imagine the 'Contact Us - Overclockers UK - Top' links at the bottom of the forum page) that I'd like to be able to link to divs that slide in and out when the corresponding link is clicked. These divs will be separate from the list (could be above or below the links), so generic accordion applications won't work. Generic sliding div solutions won't work either, as I'd like open divs to close before a new one opens, and these generally act on a single div.
    No divs are open & a link is clicked - slide open the appropriate div.
    A div is open & a different link is clicked - slide closed open div & then open the new one.
    A link to div that is already open is clicked - slide closed the div.
    In mootools, this looked like this:
    Code:
    window.addEvent('domready',function() {
        // add referring elements to an array
        var headings = $$('.collapselabel');
        // array to store all of the collapsibles
        var collapsibles = new Array();
        // for the number of elements in headings
        headings.each(function(heading, i) {
            // get corresponding div.collapse
            var coldivid = 'collapse' + heading.id.substring(13);
            var coldiv = document.getElementById(coldivid);
            // set effects for collapsible
            var collapsible = new Fx.Slide(coldiv, {
                duration: 500,
                transition: Fx.Transitions.quad
            // stores entry in collapsibles array
            collapsibles[i] = collapsible;
            //add event listener
            heading.onclick = function(){
                escapelink:
                // if collapsible is closed
                if (!collapsible.open) {
                    // slide closed any open collapsibles
                    for (var j=0; j<collapsibles.length; j++){
                        if (j!=i) {
                            if (collapsibles[j].open) {
                                // and chain-open this one
                                collapsibles[j].slideOut().chain(function(){collapsible.slideIn();});
                                break escapelink;
                    // ... open this collapsible if no others are found open
                // else if collapsible is open ...
                else
                    if (collapsible.open) {
                        // ... slide it closed
                        collapsible.slideOut();
                return false;
            // hides collapsible before display
            collapsible.hide();
    Done a fair amount of mootools, but never jQuery :o
    Thanks for any input :)
  2. Tripnologist
    Mobster
    I just wrote this out without testing, but it should work fine for you.
    jQuery
    Code:
    $('#slideNav a').click(function(e){
    	var index = $(this).parent('li').index();
    	// If selected div is already open, close it
    	if($('#slideDivs > div:eq('+ index +')').is(':visible')){
    		$('#slideDivs > div').slideUp();
    	// Else close open divs and then open selected div
    	else {
    		$('#slideDivs > div:visible').slideUp();
    		$('#slideDivs div:eq('+ index +')').slideDown();
    	e.preventDefault();
    HTML
    Code:
    	<div id="slideDivs">
    		<div>Div1</div>
    		<div>Div2</div>
    		<div>Div3</div>
    	</div>
    	<ul id="slideNav">
    		<li><a href="#">Div1</a></li>
    		<li><a href="#">Div2</a></li>
    		<li><a href="#">Div3</a></li>
    	</ul>
  3. joeyjojo
    I friggin love jquery.
  4. dave_a141
    Gangster
    Just a slight modification to Tripnologist's code so that it does the animation sequentially:
    Code:
    else {
         $('#slideDivs > div:visible').slideUp('fast',function(){
  5. A.N.Other
    Sgarrista
    Thanks gents, that's great! I'm amazed at how much more compact jQuery is then Mootools :eek:
  6. Tripnologist
    Mobster
    jQuery really is great. The size difference between your script and mine is quite drastic considering they do the exact same thing.
  7. A.N.Other
    Sgarrista
    Well not exactly the same thing, I don't think. The original would work if there were items in the slideNav that didn't correspond to items in the slideDivs, as it uses absolute referencing via elements ids. Haven't tried yours yet, but a quick scan tells me that's probably the case.
  8. Tripnologist
    Mobster
    I had actually done mine to require IDs at first, but then changed it to use index instead as I thought it more robust.
    However, changing it back to use IDs is literally a 30 second job and wouldn't increase the script size at all.
  9. dave_a141
    Gangster
    It almost feels like cheating in a way! Many times I've just looked at code and thought that it shouldn't be this easy:D
