Hello,
I have absolutely no clue about Memory, and i need some help!
I currently have:
Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/8GX)
[OCUK no longer sell this, i bought it in October 2012]
And i want to upgrade to 16GB
Could you suggest a few kits that might be suitable? Both 2x8GB Kits and 2x4GB Kits [for Add-On] (If Possible?)
Thanks a lot!
Note: The other important parts of my system are
CPU: Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor
MOBO: Gigabyte Z77-D3H Intel Z77 (Socket 1155) DDR3 Motherboard
I currently have:
Thanks a lot!
