Help meh! Cubase wont recognise ASIO...
Is the drop down list you're referring to the Devices->Device Setup->VST Audiobay?
And there's nothing in there? not even DirectX ASIO emulation..
I'd try taking two of the cards/devices out and seeing if that makes a difference. Also uninstalling and reinstalling might do something.
Check the Sound on Sound forums here. Might be useful. Helped me loads when i was starting out. Not saying that you are of course.. :p
