I have a E6300, P5W DH and Geil PC2-6400 Cas4
If i turn on SPD, set FSB to 400, (memory 1:1), everything works fine, BUT the SPD sets the timings to 5-6-6-18 or something stupid
If i set the FSB to 300, and memory running at 3:4 (so 800mhz), then manually set the timings to 4-4-4-12, its fine.
Even if i set the FSB to 366, set memory to 3:4, (so 950mhz ish), it still works fine at 5-5-5-15
Heres the problem:
I set the FSB to 400, memory 1:1, then timings to 4-4-4-12, it doesnt boot, even though the Geil is rated at this and I've already found out that the cpu can manage 2.8ghz.
Doesn't even boot with timings at 5-5-5-15.
Can someone help me plz?
Heres the problem:
