Hi
I will try and give as much detail as I can so that yoy may beable to help me.
At the community centre I help out we have about 10 pc's , 1 SBS 2003 server and one adsl router all connected to a 24 port switch.
The router is the default gateway and all the pc's take their IP info from the router(192.168.1.1). All pc's are set to DHCP and the server to a fixed IP. IP range is 192.168.1.2 onwards.
What I have done is that I purcahsed a Freecom networkable hard drive to use for server backups. As the server was the only machine free I though I would test it out on there. This is where it started going wrong
I connected the external drive to one of the spare ports on the switch and installed the Freecom software on the server. The software searches for drives and said drive found but it has different network settings. Change your network settings to match YES/NO. I clicked YES by mistake
What has now happened is that all pc's have an IP of 169.xxxx and none of them have internet acces.
How do I fix this? For now I changed the server IP settings back manually and I will change them naually ont he pcs's but we can't use DHCP anymore as the networked pc's seen to take this 169 IP instead of the 192 one they had before.
i also noticed that in attached devices on the router the server is attached twice. this is thepiconfig/all report
Host Name . . . . . . . . . . . . : llmsbs01
Primary Dns Suffix . . . . . . . : LLM.local
Node Type . . . . . . . . . . . . : Unknown
IP Routing Enabled. . . . . . . . : Yes
WINS Proxy Enabled. . . . . . . . : Yes
DNS Suffix Search List. . . . . . : llm.local
P adapter RAS Server (Dial In) Interface:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : WAN (PPP/SLIP) Interface
Physical Address. . . . . . . . . : 00-53-45-00-00-00
DHCP Enabled. . . . . . . . . . . : No
IP Address. . . . . . . . . . . . : 192.168.1.220
Subnet Mask . . . . . . . . . . . : 255.255.255.255
Default Gateway . . . . . . . . . :
NetBIOS over Tcpip. . . . . . . . : Disabled
hernet adapter Server Local Area Connection:
Description . . . . . . . . . . . : Broadcom NetXtreme Gigabit Ethernet
Physical Address. . . . . . . . . : 00-15-C5-5E-E4-80
IP Address. . . . . . . . . . . . : 192.168.1.200
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.1
DNS Servers . . . . . . . . . . . : 192.168.1.200
Primary WINS Server . . . . . . . : 192.168.1.200
How do I fix this....HELP!
