HELP! Messed up work computer
16 Oct 2007
UK
Hi all,
Picked up the fake Total XP Security package (i think from lolfbmoments).
On the work computer, which isn't good.
Can't run anti-spyware due to limited rights (ie. not admin)
Did the best I could - removed all mentions of the process from regedit, considering the process was starting up every few minutes.
Removed them all, and no sign of it again.
BUT, i've lost the file association for EXE files!
I opened IE by right clicking on the exe, then "start" rather than Open.
Same for all my exes...
Please do help!
If I was you I'd contact IT department and just tell them what has happened (you can always pretend you didn't do this).
I don't get how you can delete anything from registry without administrators privileges.
Great, thanks very much chief, seems to have sorted it out.
I thought the site in question was quite a busy, popular site.
And as you said, the offending malware is getting very clever.....
Ah, I didn't notice the new Nod32 we have also has antispyware!
Certainly didn't pick it up though, and it's supposed to be actively monitoring the system.
Doing a scan - it found the malware (a variant of Win32/Kryptik.DMR trojan) in a JPEG file in my temp internet files!
