HELP MINEFIELD
3 Jun 2025
Weston Hitchin
Help and advice please. I am looking for a small pocket-sized smart mobile phone. I am using an old DORO flip phone, and it is pocket-sized, just what I am looking for, but now looking at a smartphone all help welcome
Rooki
Depends on budget really, but, for me, the S25 is the best small phone - but it may have a host of features that you don't need or be at a price level that is beyond your means. So, other than size, what is important to you?
If you want it super compact, there's the Samsung Flip or Moto Razr phones. Depends on your budget though, but I believe the Razr ones at least are on the more affordable side.
Second the post above about the samsung s25, but if you're on a budget, getting a refurbished S24 or even S23 would be great value.
Thanks Spudgun will gogle it next. Size I think as in a pocket?
Thanks Spudgun, that's very helpful.
Ivor
