Just blown a capacitor, it can be fixed if you handy?
Screwdriver and a keen eye will find the culprit.![]()
OK find capacitor and replace doesn't sound to bad any tips?
Depends what you mean by "went bang". Actual 'bang/pop' noise, or just not turning on anymore?
Am I allowed to post a link to Overclock.net? If you do a Google search for "Samsung 226BW flickers for a few minutes when powering on" the thread will come up. First page describes replacing the caps on a Samsung 226BW. This is more for a monitor just not turning on any more due to leaking caps. If there was an actual bang/pop it might be a bit more serious.
Only posting this because my 226BW has the exact same problem, and I need to get around to doing the same soon :/
