Following my other thread regarding artifacts with my Gigabyte 580 (http://forums.overclockers.co.uk/showthread.php?t=18303102) it seems I am once again cursed with never ending GPU issues (or it could be something else).
So after getting my second Gigabyte card replaced and testing it there were still artifacts in Crysis and this was a brand new replacement manufactured in July. I thought this can't be right so thought about trying another brand.
Fast forward to yesterday. I bought a shiny new Asus 580 DCII and thought this should solve all my problems but I was wrong. I got home installed the card and did some tests. Crysis produced the same artifacts just like from my previous thread however it was worse with this card as I couldn't run it fro more than 30 seconds without it crashing. Crysis always crashes within a few seconds after displaying loads of artifacts over the screen. I then have to end it via task manager.
What I have done so far:
I have tried older drivers and the latest- Did not help
I have tried increasing the voltage on the card and lowering the clocks- Did not help
I have tried the card in my old 775 system and I got the exact same problem- Crysis crashes within a few seconds.
I did try something else today which is seriously confusing me. I tried the card in the second PCI-E slot and ran Crysis. Crysis didn't produce any artifacts and I could run it without it crashing. I thought cool, problem was a faulty PCI-E slot. I then ran Heaven which did what Crysis did when it was in the primary PCI-E slot. It froze within a few seconds, displayed artifacts and this time I had to do a hard reset as I couldn't get task manager up. I also got the message D3D11AppWindow::do_swap():device removed. Metro 2033 also crashes within a few minutes.
Not sure what else to do now. Are all 3 580's I've gone through faulty? Is something else faulty? My other system produced the same problems with all 3 580's I've tested over the last few months.
What else can I try as I'm running out of ideas?
My specs:
I5 2500K @ 4.5GHz
P8Z68-V Pro
8GB G.Skill Ripjaws
Corsair HX 750
Asus 580 GTX DCII
Also I tested my 7950GT in the system above and it runs just fine. I know it's ancient but it's the only other card I have. Probably not a sufficient test at all as it won't run Crysis/Heaven/Metro. Lol.
Any help would be great as I'm totally lost, there is no way I can be this unlucky!
My specs:
I5 2500K @ 4.5GHz
P8Z68-V Pro
8GB G.Skill Ripjaws
Corsair HX 750
Asus 580 GTX DCII
