HELP MS office wied text..
29 Jul 2008
Hi
so i was doing a document on my laptop using MS "open office" ie MS word.
I then saved the file on USB and then at home opened it via MS word.
Before i tried to open the text document it said "file conversion poped up" not sure why but i went for defualt and still it wied.
All i get is a wied text /characters example
mimetypeapplication/vnd.oasis.opendocument.textPK ‚œ%> Configurations2/statusbar/PK ‚œ%> ' Configurations2/accelerator/current.xml PK PK ‚œ%> Configurations2/floater/PK ‚œ%> Configurations2/popupmenu/PK ‚
As you see clearly not what i wanted.
any ideas?
Open office and microsoft office save as different formats, open office can be changed to save as *.doc format, try looking under options or similar then "save" options.
I would check which format you saved the file in when using "open office" ( possible .odt or similar ) which is not the same as "microsoft office" ( .doc or .docx), try opening the original file in open office and doing "save as " to save as word doc. Then try again in microsoft office.
