Hey all,
Went to go out in the car today and glow plug light flashing
I started it and revs sat as 1200 - accelerator pedal had no effect on engine speed.
Borrowed vagcom and its accelerator position sensor 1/2 as the fault. What's strange though, is the fact that if you go to measuring blocks the accelerator pedal is feeding information from 0-100% to the Ecu just as you'd expect ?!
Any ideas guys before I attempt to get to work or a garage with 1200rpm of usable 'power'.
Car is a 2000 bora tdi 115
Thanks
Thanks
