Right i am looking forwards to oblivion for the 360, so i thought i play the original first. After installing it i saw there were some good mods for it, from adding new characters, quests, weapons all the way to making the world bigger and making werewolfs and vamps better. At first a found a couple, then when i really searched i found tons of them i have no idea which i should use tbh i cant be bothered to give them all a whirl as there are hundreds of them
So anyone who has played morrowind and has used the mods can you tell me which you think i should get.
*i have the original with all 2 expansion packs*
,thxs
.So anyone who has played morrowind and has used the mods can you tell me which you think i should get.
,thxs
