- 11 May 2007
Hi
I'm trying to install my arctic freezer 7 pro on my Gigabyte GA_P35_DS3P. I thought I had fitted the heat sink OK but now I'm not so sure.
When I try fitting the fan to the heatsink it catches on the big copper silentpipe cooler to the left.
When i did this the silentpipe cooler actually lifted up the square cooper block that is sitting on the north bridge or whatever it is. It has gone back down now and seems snug - will that be OK?
I don't know what to do and I'm scared I'm going to bugger it up. Please post advice. the copper fins and the freezer fins are really close together and when the black fan is put on top, it pushes against the copper heatpipe forcing the block at the bottom to raise up.
How do I post a picture?
Any one live in Telford that could help?
thanks
Pete
thanks
Pete
