Hi, Bascially my PC freezes under the right conditions, I mean completely, freezes, no BSOD, no restart, it just becomes unresponsive, with the last screen showing on my monitor.
It happens under heaving internet use, wheth that be d/l via torrents or by using flashget download manager.
My network card is a wireless job, a cheap one at that. Do you think that'll be the problem? I've updates all the drivers, and have reformatted my PC twice to make sure it's not viruses. I just have no idea what is causing it.
Do you lot know of any way that I can check what had been causing it to freeze? Thanks.
