Have you considered this?
W32.Stration@mmRisk Level 2: Low
http://www.symantec.com/security_response/writeup.jsp?docid=2006-092111-0525-99&tabid=1
Discovered: September 20, 2006
Updated: October 3, 2006 12:03:35 PM PDT
Type: Worm
Infection Length: Varies
Systems Affected: Windows 2000, Windows 98, Windows Me, Windows NT, Windows Server 2003, Windows XP
Once executed, worms from the W32.Stration family may perform some of
the following actions:
Contacts remote hosts.
Downloads and executes remote files.
Gathers email addresses from the compromised computer.
Sends itself to the email addresses that have been gathered. The email may have some of the following characteristics:
[SPOOFED]
Subject:
One of the following:
Good Day
Server Report
hello
Status
test
Error
Mail Delivery System
Mail Transaction Failed
Mail server report.
Message:
The message contains Unicode characters and has been sent as a binary attachment.
Mail transaction failed. Partial message is available.
The message cannot be represented in 7-bit ASCII encodingand has been sent as a
binary attachment
Mail server report. Our firewall determined the e-mails containing worm copies are being sent from your computer. Nowadays it happens from many computers, because this is a new virus type (Network Worms). Using the new bug in the Windows, these viruses infect the computer unnoticeably. After the penetrating into the computer the virus harvests all the e-mail addresses and sends the copies of itself to these e-mail addresses. Please install updates for worm elimination and your computer restoring.
Best regards,
Customers support service
body
data
doc
docs
document
file
message
readme
test
text
Update-KB[RANDOM NUMBER]-x86
Note: The file name of the attachment may use a double extension, for example body.txt.exe.
RecommendationsSymantec Security Response encourages all users and administrators to adhere to the following basic security "best practices":
Turn off and remove unneeded services. By default, many operating systems install auxiliary services that are not critical, such as an FTP server, telnet, and a Web server. These services are avenues of attack. If they are removed, blended threats have less avenues of attack and you have fewer services to maintain through patch updates.
If a blended threat exploits one or more network services, disable, or block access to, those services until a patch is applied.
Always keep your patch levels up-to-date, especially on computers that host public services and are accessible through the firewall, such as HTTP, FTP, mail, and DNS services (for example, all Windows-based computers should have the current Service Pack installed.). Additionally, please apply any security updates that are mentioned in this writeup, in trusted Security Bulletins, or on vendor Web sites.
Enforce a password policy. Complex passwords make it difficult to crack password files on compromised computers. This helps to prevent or limit damage when a computer is compromised.
Configure your email server to block or remove email that contains file attachments that are commonly used to spread viruses, such as .vbs, .bat, .exe, .pif and .scr files.
Isolate infected computers quickly to prevent further compromising your organization. Perform a forensic analysis and restore the computers using trusted media.
Train employees not to open attachments unless they are expecting them. Also, do not execute software that is downloaded from the Internet unless it has been scanned for viruses. Simply visiting a compromised Web site can cause infection if certain browser vulnerabilities are not patched.
