HELP ! Need Advice
3 Jan 2007
Hi
The back light on Samsung SM-226BW 22" Widescreen LCD bought in March 2007 from overclockers is playing up so I'm looking for a replacement.
Original spec of the Samsung monitor as below
22in - TN Panel
16:10 (widescreen)
1,680x1,050
2ms refresh
300cd/m2
3,000:1
160/160 degrees
DVI-D, D-Sub, RGB, HDCP
I can't fault the monitor until last night, needless to say with not buying a monitor in the last 7 years I'm a little out of touch with what's good out there.
I'm looking to upgrade a couple of inch in size to a 24" and would like a monitor with both DVI and HDMI if possible, also with a thin bezel
I mostly use the monitor for standard web use, but I still play Day of Defeat most days, so I would prefer a monitor that can handle a fast FPS game.
I sit directly in front of the monitor so I'm not worried about viewing angles.
Price range £100 - £200'ish
Any suggestions ?
