Help need on a new water cooling case pump
7 Feb 2003
I am looking for some help on building my first water cooling case system
I have decided to go with Alphacool Ready2Go Stacker Silver case which comes with the following installed:
CPU cooler: NexXxoS XP Rev.2 for AMD
Radiator: NexXxoS Pro III
Fan: 3x Alphacool 120x120x25mm 1200rpm
Pump: AGB Eheim 600 Station 230V/12v
Hose: 10mm
I need some help in selecting a pump and Connections which type to use screw or push?
I am swaping out the supplied AGB Eheim 600 Station 230V/12v and replace it with an Alphacool:
Laing DDC 12V ULTRA Pump & Plexitop or
Laing D5-Pump12V D5-Vario with 1/2 with screw connectors?
The plan is go to move to a DFI LanParty UT CFX3200-DR RD580 Crossfire (Socket 939) PCI-Express Motherboard and water cool the complete system
Thanks
Simon
Hi Tom,
Cost for the standard Alphacool Ready2Go Stacker Silver case is £240
I will need to pay the difference when I upgrade the pump maybe a extra £20
Simon
