Man of Honour
- 29 Mar 2003
- Stoke on Trent
I'm having a major problem getting rid of malicious code sitting in a directory called Netproject.
This is causing so much trouble with naught pop-ups etc.
The two main files will not END PROCESS in TASK MANAGER.
You can't delete them from file manager.
The PC won't boot into SAFE MODE (any of them)
I've tried KNOPPIX which I thought would work but I can't delete any files that are on the c:\ drive.
I made a bootable floppy but for some reason I can't go from the a:\ prompt to c:\ (it says invalid drive specification)
The owner doesn't want me to format.
Any ideas?
Any ideas?
