Help - need XBCD drivers for vista 64bit
5 Dec 2006
Hey, does anybody know how to get the XBCD drivers to work in Vista 64 bit?
I previously used them with Vista 32 bit fine.
I would run the install wizard, then plug the controller in, and then windows would automatically find the drivers, and then a prompt used to come up that said "the drivers are not digitally singed" or something like that, then i used to hit "install anyway" and everything was perfect.
BUT now on vista 64 bit, i plug the controller in and it says it cant find any drivers :(.
Thanks!
XBCD drivers generally don't work in 64 bit Vista without some serious messing about. Used to work pre-sp1 as you could force the unsigned driver but you can't any more. There is a way of running Vista in test-mode which allows you to test unsigned drivers but it is a major pita.
I'm just using the drivers available on windows update, seems to work fine for me..
Tho I'm sure I've used the XBCD drivers without issue too, on vista64
you may have used them pre-sp1 but they certainly do not work now without "testing mode" being enabled.
tried playing any of the NFS series? They all suck with the MS drivers. Can barely drive in a straight line.
I refer you to this thread:
http://forums.overclockers.co.uk/showthread.php?t=17869836
Specifically, the following post:
http://forums.overclockers.co.uk/showpost.php?p=11582776&postcount=5
Driver Signature Enforcement Overrider
NGOHQ.com posted version 1.0 of their Driver Signature Enforcement Overrider
Microsoft did well bringing the 64-bit architecture to Windows Vista but somehow they screwed up. Apparently they forgot who their target audience was when they introduced a very restricted module of driver signature enforcement. In laymen's terms, all drivers and system files must be digitally verified or they cannot run when using the 64-bit version of Vista. In the past it was possible to turn that feature off; but due to new kernel security updates it is impossible to turn it off without degrading security and stability of your operating system.
In order to turn this off it involves uninstalling critical security updates that Microsoft has released to increase system security. Sadly, this feature makes Windows Vista 64-bit into a closed and locked down operation system.
So what's the problem with digital certificates? Well, the problem is. developers have to pay Microsoft to receive verified certificates, and that makes many applications inaccessible under Windows Vista 64-bit. This driver signature enforcement can be a serious pain to end-users; however it is still possible to turn it off by disabling it up by pressing the F8 function key during system boot up.
Pressing F8 every time on boot up can be a serious pain in the ass and frustrating to those that miss the time window available to press F8 during start up. Others have found workarounds, but most of them are too complicated for the average end user to perform, atleast until now.
http://www.ngohq.com/home.php?page=dseo
Worked a treat for me.
I now switch between the XBCD and the Official drivers whenever I like :)
