help needed £150 upgrade
5 Feb 2007
what do you guys recomend? this is for a mate
Abit IP35-E (Socket 775) PCI-Express DDR2 Motherboard Abit IP35-E (Socket 775) PCI-Express DDR2 Motherboard £54.99
(£64.61) £54.99
Intel Core 2 Duo E2160 "LGA775 Conroe" 1.80GHz (800FSB) - Retail Intel Core 2 Duo E2160 "LGA775 Conroe" 1.80GHz (800FSB) - Retail £41.99 (£49.34) £41.99
GeIL 2GB (2x1GB) PC2-6400C4 800MHz Ultra Low Latency DDR2 Dual Channel Kit (GX22GB6400UDC) GeIL 2GB (2x1GB) PC2-6400C4 800MHz Ultra Low Latency DDR2 Dual Channel Kit (GX22GB6400UDC) £34.99
(£41.11) £34.99
Or
AMD Athlon 64 X2 Dual Core 4800+ 2.50GHz (Socket AM2) - Retail
£63.44 inc VAT
(£64.61) £54.99
(£41.11) £34.99
MSI K9N Neo V3 nForce 560 (Socket AM2) PCI-Express DDR2 Motherboard
- NVIDIA nForce 550 MCP chipset
- Supports AMD Socket AM2, Athlon64 FX/X2 and Sempron processors
- 1 PCI-E x16 slots for VGA
- 4 dual channel DIMMs DDRII 533/667/800 up to 8GB
- Gigabit LAN 10/100/1000
- 7.1-channel High Definition Audio
- Supports 4 SATAII, storage and data transfer up to 300MB/sec
- 2 PCI-E x1, 3 PCI slots
- 10x USB 2.0
- Silent Heatsink design
£46.99 inc VAT
your help would be apreciated
thanks ben
Abit IL9 Pro (Socket 775) PCI-Express DDR2 Motherboard
Intel Core 2 Duo E2180 "LGA775 Conroe" 2.00GHz (800FSB) - Retail
GeIL 2GB (2x1GB) PC2-6400C5 800MHz Value DDR2 Dual Channel Kit
£147.13
any one else?
Are you after cheapness or speed?
I dunno what he already has but this board offers DDR & DDR2 and an AGP slot as well as PCI-E if he is on quite an old board etc. So if he has a GB of DDR then you can use that for the time being to save some monies.
Same with the GFX card, if he has an AGP he can use that then upgrade later.
If not and he has PCI-E then I would prob get a better board (the ABit one) and get some DDR2 RAM as it's cheap as chips now anyways.
Also you would have to OC that chip to get your monies worth so a decent CPU cooler could also be on the cards... Dunno how well the stock coolers do when OC'ing.
(£41.11) £34.99
Asrock 4CoreDual-SATA2 (Socket 775) PCI-Express/AGP DDR2 Motherboard £36.99
(£43.46)
Intel Core 2 Duo E2140 "LGA775 Conroe" 1.60GHz (800FSB) - Retail £35.99
(£42.29)
Sub Total : £107.97
(This can be changed during checkout) Shipping : £8.25
VAT is being charged at 17.5% VAT : £20.34
Total : £136.56
Cheers, Doug.
