Help needed - 2Gb modules & 680i Mobo
2 Nov 2006
I got 2x2GB of DDR2 800Mhz OCZ on Monday along with my other components. I didn't realise until I read the motherboard manual (BFG nForce 680i) that it only takes up to 1GB sticks of RAM. I plan on returning this RAM and purchasing 1Gb sticks, but just incase, is there any possible workaround to this problem?
Thanks guys.
I think thats only because the manual was printed when there were no 2GB Modules.
I seriously doubt your mobo (same chipset as mines) cant run 2GB Modules so 2 x 2GB = 4GB as I ran 4GB before.
All you need to see all 4GB in Windows is 64bit version of XP or Vista and update your Mobo bios to latest when arrives so you have leatest support for Memory etc.
