Help needed - 50hz no play on outfit
17 Dec 2003
Peterborough
Hi all,
I have purchased Outfit and it states I can only play if it is set to 60hz. Tells me to go into the Dashboard and sort it through the display settings.
My problem is there is no settings in there for the Hz my TV is running at :confused:
Using component on a 32" Philips LCD
Any ideas or help greatly appreciated :)
Found it :)
When you're running in high-def it doesn't give you the option, plug it into a standard component input (or anything else which gives you SD output) and it'll let you change it to 60hz, then you can plug your HD stuff back in again.
Glad you found the solution matey, I was just looking into it myself.
Couple of flaws for the Xbox live updates:
1. Why can't it run in both modes like other games?
2. Why can't you change the system option without having to faff about with cables?
I dunno but I spent the best part of an hour falling out with the 360! Knew I should have googled the 1st time :)
