Hi Guys, I was hoping that someone might be able to give a pointer as to what the problem is with my system, firstly here is my system specs.
[email protected]
2x1gb Corsair xms26400c4
Asus P5wW-DH Bios 2004 although all others tried!
BFG 8800GTX OC
Enermax Noisetaker 600w 2x18amp rails
2 x DVD writers
1 x floppy
1 x WD RaptorX
1 x Seagate 160gb
Xfi Extreme Gamer
1 x PCI USB Hub
Water cooled using D5 pump,PA120.1,PA120.2
and a total of 8 fans nexus and noctua
XP PRO SP2 all updates and hotfixes
All Nvidia drivers tried
Now the problem I get is with newer games ie, Bioshock,Graw2,MOH Airborne and Crysis beta I get random crashes, which leaves me with the screen going all corrupted as per the link.
http://www.r5jones.aquiss.com/Pictures/8800 Coruptionpost.jpg
http://www.r5jones.aquiss.com/Pictures/8800 coruption2post.jpg
Once this happens the pc will either just sit there or evetually reboot, sometimes I can her the game sound looping other times nothing. I can not alt-tab out of game, the only thing I can do is to force shut down and reboot the system. I get no error messages and there is never anything in event viewer, I have unticked auomatically restart and never see a bsod.
Things I have done to try and resolve this are 2x reformats, various drivers, underclocking the card down, unpluging as much as I can to reduce load on PSU, running cpu at its normal speed, reinstalling DirectX,setting fan to 100 percent when stock cooler fitted, removing the side of the case and aiming deskfan at it, the system will pass 12hrs Orthos Small FFT,s and run Memtest until I stop it with no errors,now if I run a older game such as HL2,Farcry,COD2 on max settings I have no isssue,s.
Anyway BFG support are starting to point there fingers at the PSU even though it appears to meet the requirements,so my train of thought is that maybe I do need a new power supply with higher rated 12v rails or the card is faulty. But the card shows no other signs or corruption in games and can run fine for hours or crash in minutes, with Bioshock it is possible to replicate the crash nearly every time in the same area! Any comments would be great as I am getting quite frustrated now and have no where to test the card as nobody I know has a psu capable of running it.
[email protected]
BFG 8800GTX OC
2 x DVD writers
1 x floppy
1 x WD RaptorX
1 x Seagate 160gb
Xfi Extreme Gamer
1 x PCI USB Hub
