Hey folks, hope you can help me out. I jsut purchased the components for a new PC, my last build was a few years ago so I am very rusty.
Questions:
1. OK my motherboard (Abity IP35V) has the following headers for connecting fans:
I know I plug the heatsink fan into the CPU header but I wanted to know if it is wise to plug the three case fans that came with my Coolermaster 690 directly to the motherboard points?
I have a 500w Antec PSU, not sure if that matters, the reason I am asking is that it would simply keep the case less cluttered rather than connecting them to the PSU as I wouldnt have to use those adapter things.
2. Next question is about the AUDIO headers on the case, I have one 'clump' of headers together, kind of glued together, but I also have individually headers.
Am I right in thinking that I simply use the clump and plug that into the motherboard if it fits (99% certain it does), and that the single headers are for motherboards that have a different header setup?
3. Next question is about the IO plate thing, I have never understood what to do with these. does it simply fit in the hole and the ports like mouse/keyboard/USB fit through?
The IO panel that came with the motherboard has very sharp points coming out of the sides of the holes, do I tear those off?
Thanks folks
Questions:
- CPUFAN
- SYSFAN1
- AUXFAN1
- AUXFAN2
Thanks folks
