Help needed, confused over 120hz and laptops
3 Feb 2012
Hi,
I'm running an nvidia 580GTXm gpu and was looking to buy a benq XL2411T but after some research I'm not sure I'd be able to use the full refresh rate.
Can anyone please advise?
Thanks
Jace
You will need either dual link DVI output or a proper displayport connector (not an adaptor from HDMI/DVI) and a monitor that supports one or both of those connections.
Another thing I found - the displayport on most laptops that have it seems even more sensitive to cable length and quality than desktop GPUs - on many of them anything beyond ~1.8-2meters won't be able to drive 120Hz.
