Help needed: electric shower
28 Aug 2003
Portsmouth
Hi does anyone have knowledge about electric showers?
We have a Triton Caselona 2 and basically there is no hot water.
There is no problem with water flow/pressure in our area.
The lights come on, the water flows, but it's cold.
There is no water leakage.
I *think* no problem with water heating elements as when the temp knob is turned all the way to hot, hot water does come out but it's scorching. Then turning the knob slowly anticlockwise (to reduce temp) the water suddenly switches to cold.
After googling, I'm thinking that it's just the TCO (thermal cut out) that needs replacing.
Am I right? Thanks in advance to anyone that can help.
There is next to nothing in an electric shower
Open it up and take a look (make double sure power is off!) thermal cut outs tend to burn out and they visibly melt
This is the most common issue with electric showers
Odd though that it does work at very high temperatures
Yeah basically the heater is running full whack all the time and it's just the flow control that dictates how hot the water comes out. Wierd that it should just cut off suddenly.
