- 4 Nov 2002
- England - Leeds
Hi there, basically I was wanting to make a little setup at home for those times when I cant make it to the gym or holidays when the gym is closed. The only thing I can't seem to find at the moment is the dumbbells, whenever I look at websites they only go upto 30kg 99% of the time.
I probably cant bench as much as you guys, at my gym the dumbbells only go upto 40kg to I have to bench with a barbell and my max right now as I'm cutting still is 135kg so I was thinking I'd like a pair of dumbells which are around 50kg each but you just can't seem to find them that heavy on any websites?
Also I'm still not sure if I should go for those adjustable types which go from 20-50kg or seperate ones, not sure which are better and which will be cheaper.
EDIT: At my gym I use 8kg, 12kg and 14kg dumbbells for shoulders, I use 40kg for chest as thats all they have, but I'd like 40kg, 45kg and 50kg dumbbells, maybe even higher upto 65kg.
I can find benches and squats racks and everything else I need, I just cant seem to find heavy dumbbells.
Thanks in advance.
Thanks in advance.
