Can you please help on this build I will be getting in the coming weeks, and are there any compatibility issues?
Any suggestions on what can be changed or improved without a radical change in price?
The cheaper the build is, the better.
Are there any cheaper options?
My Build:
Corsair LP Vengeance 16GB 1600MHz CL9
Intel Core i7-2600K 3.40GHz (Sandybridge) Socket LGA1155 - http://www.overclockers.co.uk/showproduct.php?prodid=CP-358-IN
Pioneer 24x Internal S19LBK DVD Rewriter - http://www.overclockers.co.uk/showproduct.php?prodid=CD-075-PO
Western Digital Caviar Black 1TB SATA 6Gb/s 64MB Cache - http://www.overclockers.co.uk/showproduct.php?prodid=HD-336-WD&groupid=701&catid=14&subcat=
Gainward GeForce GTX 580 "GOOD Edition" 1536MB GDDR5 PCI-Express - http://www.overclockers.co.uk/showproduct.php?prodid=GX-141-GW&groupid=701&catid=1914&subcat=1812
Cooler Master HAF X with Coolermaster GX 750W PSU - http://www.overclockers.co.uk/showproduct.php?prodid=CA-233-CM
Noctua NH-D14 Dual Radiator CPU Cooler - http://www.overclockers.co.uk/showproduct.php?prodid=HS-011-NC
Asrock Z68 Extreme4 Intel Z68 (Socket 1155) DDR3 Motherboard - http://www.overclockers.co.uk/showproduct.php?prodid=MB-051-AK
OCZ Vertex 2 50GB 2.5" SATA-II Solid State Hard Drive - http://www.overclockers.co.uk/showproduct.php?prodid=HD-040-OC&groupid=701&catid=14&subcat=910
Is the Coolermaster GX 750w Power Supply that comes with the HAF X enough? Or will it be better to get this:
OCZ ZX Series 1000W '80 Plus Gold' Modular Power Supply - http://www.overclockers.co.uk/showproduct.php?prodid=CA-053-OC
The Monitor I will be using is:
ASUS VE247H 24 inch LED Widescreen Full HD 1080p -
TKS FOR ANY HELP!!
Are there any cheaper options?My Build:
TKS FOR ANY HELP!!
Tarr, and sorry again
