Help needed for PSU!
28 Feb 2013
Leeds
Hello fellow overclockers!, I do apologise if this is in the wrong section of the forums, I could find one for PSU's.
Down to the issue.
I am currently modding a DELL OptiPlex GX260 Desktop Low Profile Case for a HTPC.
The issue I have is, a standard PSU (ATX) Will not fit.
I need to have one that can fit in a gap of around 9cm Wide x 9cm High x 10+cm Long (length isn't an issue really, just height and width).
Are there some PSU's out there that support 24pin motherboards and are around the 300-400watt mark ?, I have looked at PICO PSU's but they are crazy expensive for such a little PSU!
Any help would be great appreciated :)
Regards
Jonnyp
An SFX Psu is what you are looking for.
SFX has dimensions of 100 x 125 x 63.5 (width x depth x height in mm) with 60 mm fan. Optional 80 or 40 mm fan replacement increases or decreases the height of the unit
Hi. Just being looking at sfx psus and the only ones i can find are either 125mm or 100mm wide.
I need one thats no bigger than 90mm wide and 90mm high.
Is there any others out there that small or am i just going to bite the button and go for a pico ?
Regards
Jonnyp
