- 2 Aug 2006
Hey all,
The components below are the components im going to be using in my new PC build that I'll be building next week.
CPU - AMD Athlon 64 X2 5000+
Mobo - Asus M2N-E Socket AM2
RAM - OCZ 2x1GB PC 5300 Dual Channel GX XTC
GFX Card - XFX GeForce 7800 GTX 512Mb PCI-E
PSU - 580W Hiper Type-R Blue
HD - 300GB Maxtor D/Max +10 SATA [16MB]
Optical Drive - NEC ND-4570 DVD-RW/RAM
Case - Aspire X-Cruiser Blue
OS - Windows XP Pro (x64 Edition)
I've already purchased the case, PSU and HD.
What I'd like to know is if I purchase all these items, will they all work in sync with each other and come with the correct cables that I need etc.
PLUS, will the CPU come with a Heatsink? AND I heard you should use thermal paste when putting the heatsink on? Will that come with it?
Thanks,
Marky
Thanks,
Marky
