Help needed MSI Optix 27"
10 Jun 2009
Darlington
Hi all.
Im having an issue with mu monitor.
Its not displaying full screen on 2560 x 1440 resolution on display port.
The screen has a black .5 cm border all round the left, right and top edge.
I can move the mouse cursor to the top of the screen and the left of the screen and it still stays visible but it will disappear from sight at the bottom and right side of the screen.
Ive tried allsorts of fixes and all to no avail.
Any help out there??
Are all your drivers up to date & have you played around with scaling?
It might be worth changing the resolution and seeing if you get the same issue at 1080p, then switching it back to see if it populates the whole screen.
Or there might be a screen size option within the monitors display settings
Hi all.
Isn't there adjustment options in the OSD via the nobbly joystick at the back of the monitor? I'm sure there is on my 24" version.
