Hi guys, right, basically Ive purchased a York 2001 Multigym off ebay for the sum of £60, very happy with it and got it now set up in the garage at home.
I was given the choice and chose to dismantle the item at the sellers address to give me a better idea of how to put it all back together again when I got it home.
The query comes about the cables, should they all be attached to the weights all the time or should I be selecting each cable as and when I require it for a certain position or setting. At the moment for example I use the chest bars (no idea of the real name lol) and its lowering other pieces of kit and slackening off all the other cables. Just doesn't look right IMO.
Perhaps Im being thick, the item only came with exercise instructions and not assembly instructions! So I cant check anything at this end!
Thanks in advance for any help on the matter!
