Deleted member 61728
Hi i have problem here are my specs:
Q6600 @3.0ghz
4 gigs ram
1 X 150 raptor 10000rpm [problem drive]
2X 500 gb seagate HD
I have a dual boot system with xp/vista xp on the raptor and vista is on a partion on one of the seagates.
The problem is i can boot into xp and safemode but after a short while the raptor makes a funny noise and blue screens with a crital process was terminated error even though i havnt dont anything.Ive tried doing a av scan and error checking of the drive + defragging +tried doing same in safemode but this all fails also.
Ive tried booting into vista but this fails aswell it says winload file is missing on the raptor.So i tried using the win cd recovery console to no luck.
Some cricital files are on that hardrive and i cant backup them up is there anything i can do to get them back ?
Is this a borked HD or something else ?
How would i fix this problem without getting a replacement raptor and what stepsdo i need to follow to get at least one of os system working today with minimal effort?
Thanks in advance
Q6600 @3.0ghz
4 gigs ram
Thanks in advance
