Help Needed on Upgrades
27 Nov 2014
This is my Current PC System:
YOUR BASKET
1 x EVGA GeForce GTX 980 Superclock ACX 2.0 4096MB GDDR5 PCI-Express Graphics Card (04G-P4-2983-KR) £469.99
1 x Gigabyte Z97X-UD3H-BK - Devil's Canyon Core i7 4790K CPU & Motherboard Bundle **£15 Saving + Gigabyte Free Upgrade ** £403.98
1 x SuperFlower Leadex Platinum 1000W Fully Modular "80 Plus Platinum" Power Supply - Black £161.99
1 x Microsoft Windows 7 Ultimate SP1 64-Bit - OEM (GLC-02389) £146.99
1 x Kingston HyperX Beast 16GB (2x8GB) PC3-19200C11 2400MHz Dual Channel Kit (HX324C11T3K2/16) £129.95
1 x Bitfenix Colossus Venom Green LED Big Tower Windowed Case - Black £119.99
1 x Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST2000DM001) HDD £64.99
1 x OcUK 24x DVD±RW SATA ReWriter (Black) - OEM £19.99
Total : £1,535.57 (includes shipping : £14.75).
Im looking to upgrade my cooler from stock intel to this cooler:
YOUR BASKET
1 x Phanteks PH-TC14PE CPU Cooler - Black £69.98
Total : £75.96 (includes shipping : £4.98).
But am I able to change the stock fans with these fans :
YOUR BASKET
1 x BitFenix Spectre PRO 120mm Fan Green LED - Black £11.99
Total : £14.96 (includes shipping : £2.48).
Also I would like to upgrade to an SSD, this is the SSD im looking to buy
YOUR BASKET
1 x Samsung 256GB SSD 850 PRO SATA 6Gbps 3D NAND Solid State Drive (MZ-7KE256BW) £144.98
Total : £154.58 (includes shipping : £8.00).
Are there any other good SSD which are cheaper but with same specs ?
Budget for both around £250-300
Thank You
Is there much difference between the samsung 850 ssd and the Crucial MX100 SSD ?
I doubt very much you could tell the difference between them if you had tow identical systems side by side, its the sort of thing you need benchmarks for to show the difference.
But there is a large warranty difference.
ahh ok cool, il go with the Crucial MX100 SSD, but get 512GB.
Just to finalise things you 100% sure this Heatsink Noctua NH-U12S Ultra-Quiet Slim CPU Cooler with NF-F12 Fan will be compatible in my case and the Bitfenix Pro fans can replace the stock Fans
You can use the same key for the OS.
As for the cable bundle.....superflower have a patent or something on their connector design so there are no direct replacement braided cables for it, only extensions.
