Hi all, i am in need of a lil help.
My PC will not boot into windows. Here's what happened, ive been using pc all day then notice it lagging when opening a mp4 video in QT. so i tried to open task manager to close QT and it gave me an error. I then tried Ctrl Alt Del and same weird error. so i went to reboot. Now i get this:
Every time I boot, the green bar scrolls across the screen thinks for a lil while, the mouse cursor shows up and for a split second i can move the mouse, but then the PC reboots. Upon rebooting, my system fails to detect that there is a raid. and ofc goes through the motions of booting but fails to find the OS. (This does not find the raid thing has happened before and usually i just reboot and its all ok) But now when i reboot the whole thing just repeats it self.
I have done 3 window repairs which tried 2 system restores and on the 3rd one it says it cannot do anything else.
I consider myself a fairly knowledgeable and safe user. I run and do weekly scans of kaspersky AV, spybot S+D, maywarebytes anti malware, superantispyware
Hardware:
Q6600
Abit IP35 pro
4x 1gb Gskill HZ 6400
Now i do have my CPU overclocked so I have put it back to stock speed of 2.66ghz. But im not sure what the stock voltage is for the CPU (maybe its getting too hot - unlikely but ill try) so i've put voltage down to 1.25. I still get the same process repeating. I've also tried booting into safe mode with the same results.
My next suspicion is the raid is at fault i really really hope it isnt
any ideas what to do next or what to check?
any help is much appreciated and thanks in advance.
Hardware:
Q6600
Abit IP35 pro
any ideas what to do next or what to check?any help is much appreciated and thanks in advance.
